"Check Engine" error PO128
Old May 29, 2018 | 04:02 PM
Tarheel61's Avatar
Default "Check Engine" error PO128
I am trying to find out if I was ripped off at the dealer for repairing this. They replaced the thermostat and flushed the anti-freeze and replaced it. For that one thing it was $432.
Old May 29, 2018 | 04:19 PM
ronjenx's Avatar
If the problem is gone, then you didn't get ripped off as badly as it seems.
Each code has a list of possible causes. It takes time to go through the list.
Too often the dealer will not go through the list, but instead just throw parts at it, charging the owner for each unnecessary part and labor. That's getting ripped off.
Old May 29, 2018 | 05:05 PM
Rednroll's Avatar
From my experience with my dealership, they wanted $185 just for the OBD2 scan. So considering that cost on top of any further diagnosis, labor and parts, $432 doesn't seem too unreasonable from the dealership for the work they did. This is one of the major reasons I purchased a BlueDriver OBD2 scanner which can read everything the dealership can read, and do my own repairs and diagnosis, or if I can't do my own repair, I may tell them to replace certain parts based upon my diagnosis and research of what I determined needs to be done. That gets me away from the $185 OBD2 scan charge, but then the responsibility falls on my shoulders if the repairs I authorize doesn't fix the problem.
My local shop charges $80 for the OBD2 scan, and their labor rate is typically 1/2 the dealership hourly cost. So you have a few options in the future. Do it yourself, take it to a shop and pay about 60% of dealership costs, or pay the dealership rates.
How were you able to determine the original problem logged a P0128 code? If from the dealership, then yeah....you likely paid around $185 for them to tell you that piece of information.
Old May 29, 2018 | 06:38 PM
resharp001's Avatar
Loved
Community Favorite
Well, surely you were advised before hand what the cost was going to be, and decided to go through with it. Any service at the dealer is a screw job. 2 gallons of coolant = $50, a thermostat = $25, and should have just replaced coolant sensor at same time for $25, few gallons of distilled water.....the rest is just labor. Either do the labor yourself, or pay for the convenience of not doing the labor yourself. It's an easy DIY job......but I guess if you don't DIY things.....maybe intimidating?
Old Nov 4, 2018 | 10:53 AM
cruzitto's Avatar
Default "check engine" code PO128
been having this problem 2 months since lifting my 2012 rubicon 3.5". I recently bled the coolant and replaced the thermostat. I tried to erased the code but it wouldn't let me. any advice?
Old Nov 17, 2018 | 02:30 PM
cfarq's Avatar
i had the check engine light with P0128. I replaced the thermostat for 20$ and flushed the system and added new coolant for 20$. So that being said you could have done it yourself for about 40$ total plus your time in labor. I disconnected the positive terminal from the battery for 5 min and the check engine light has been off for about 48 hours now. We shall see if it comes back.
Old Jan 14, 2019 | 10:23 PM
JDub1306's Avatar
Default Aggravating
Had this code come up in south Florida. Changed the temp sensor on the block and didn't have any issues for about a year. (33'' tires with leveling kit) Moved to Colorado, lifted "Warchild" 2 1/2", put 35'' tires on, installed Flowmaster exhaust, Flowmaster cold air intake, and the code came back. No coolant leak, sensor intake is operational, coolant level is perfect, and after about two weeks, the code came back. I cleared the code and it lasted about two more weeks.
Suggestions?
Old Jan 15, 2019 | 05:15 AM
resharp001's Avatar
Loved
Community Favorite
Suggestions?
I had this code as an issue before, always when really cold outside, and usually when visiting my dad up in Colorado (cold again). I changed my sensor, and the code would still pop up time to time. replaced thermostat and never came back. I suspect that my thermostat was getting sticky in the open position, not allowing my engine to come to temp quick enough to satisfy the computer. I think faulty thermostat is way more likely than faulty sensor.
Old Jan 15, 2019 | 11:16 PM
JDub1306's Avatar
Thanks brother. If it comes on again, I'll replace the thermostat. So far it's been three days and no code. I appreciate the response.
Old Feb 22, 2019 | 02:57 AM
Jahamm88's Avatar
@resharp do you think the thermostat sticking open could be a no heat or poor heat/inconsistent heat inside vehicle cause ? Some days I've got it blazing hot, others not so much mostly on super cold days. And the code is also come and go depending on the outside temps
