Check engine light at 1100 miles
Old Mar 13, 2012 | 12:36 PM
zoranz's Avatar
Default Check engine light at 1100 miles
Hey guys. Haven't had a chance to bring it to the dealer but a check engine malfunction light popped on. Checked the manual and it said it could be a loose gas cap or some other malfunction. Not very helpful. I checked the oil, looks fine. The jeep is running fine. Not sure what it could be esp since its so new. Kinda worried I may have gotten a lemon.
Jeep is 2012 Sahara jku. 6 speed manual. Any suggestion or things to check out would be greatly appreciated.
Old Mar 13, 2012 | 12:47 PM
zoranz's Avatar
One more thing it's a solid check engine light. Not blinking.
Old Mar 13, 2012 | 12:53 PM
thedrod's Avatar
Take it to the nearest autoparts store and have them read the code. Most places do this for free.
Old Mar 13, 2012 | 12:58 PM
Noxian's Avatar
You can also read the code through the evic, if you dont have the evic you can flick the key 3 times between off and run and leave it in run the 3rd time.
Old Mar 13, 2012 | 02:42 PM
Hibagons's Avatar
My 2012 did the same thing. The light came on at about 1000 miles. Then went out, then came back on. Took it to the dealer and they said it was showing a code for the power door locks. It came back on within the next 200 miles. It went out, then came back on, again and again. Went back to the dealer and it should a code indicating a problem with the fuel system, possibly caused by the oxygen sensor. I left the dealership and it came back on within 200 miles. Then off, then on again. I bought the Gibson dual cat-back exhaust system a week later. Since I installed the exhaust I haven't had another check engine light. Could be a coincidence, but I don't think so.
