Sponsored by:
Sponsored by: DashLynx
Door Leak
Old 09-05-2018, 12:20 PM
dmalpas's Avatar
Default Door Leak
Guess I am the only one with this problem???
Our 2014 hardtop JK leaks around the molding at the top and most forward point of the driver's door. The molding looks exactly the same on both sides, but only the driver's side leaks. [original molding] If the wind is blowing the water comes right in.
The curious thing is that it looks like the molding has been trimmed.
Old 09-18-2018, 07:08 PM
tango romeo papa circa 67's Avatar
No, you are not. My hard top has been leaking since new. Replaced the moldings under warranty, made the situation worse. Used all my Aerospace Repair & Overhaul skills(tried trimming @ caulking) to no avail. Gave up and pulled the drain plugs. Don't crank the wings to tight, you will get leaking from the center speakers, and over the radio console. It gets really bad here in the winter, freeze and thaw. I park facing uphill to discourage water getting in.
Old 09-19-2018, 02:49 AM
dmalpas's Avatar
Sounds like your leak is center-line from the removable panels, while mine is from the forward end of the driver door. The area of the molding that looks like it has been trimmed, but has not. See picture.
Old 09-20-2018, 03:04 PM
jedg's Avatar
Not sure if this document will help you or if I have the permissions right... It's the water leaks repair manual that Jeep uses.
https://drive.google.com/drive/folde...2VXNEpqN3ZaNEk
dmalpas (09-20-2018)
Old 09-20-2018, 03:23 PM
dmalpas's Avatar
[QUOTE=jedg;4328901]Not sure if this document will help you or if I have the permissions right... It's the water leaks repair manual that Jeep uses.
/QUOTE]
Well, isn't that just handy. Much appreciated.
Old 09-20-2018, 03:24 PM
jedg's Avatar
[QUOTE=dmalpas;4328905]
/QUOTE]
Were you able to get to it? Just want to know so that I can be sure I have the permissions correct.
Old 09-21-2018, 06:47 AM
dickgillberg's Avatar
I've had exact the same problem with my 14 JK. It's still there but when I use silicon grease on the rubber parts, on the doors and roof, it will go away for a time until it dries out again.
Old 09-21-2018, 11:46 AM
tjkamp's Avatar
Mine dose as well. Has since it was a few months old.
Both vehicles I have had with removable roofs have been this way.
Quick Reply: Door Leak
