Code P0430 CATALYST EFFICIENCY (BANK 2)
Old 01-18-2010, 05:03 AM
JK_Oman's Avatar
Default Code P0430 CATALYST EFFICIENCY (BANK 2)
I've got this code P0430 CATALYST EFFICIENCY (BANK 2)
went to a muffler shop, checked everything no damage found
but the code came again, could it be the sensor itself?
Old 01-18-2010, 06:22 AM
derby911's Avatar
most likely a bad cat should be covered under warranty at least to 50'000 miles
Old 01-18-2010, 07:09 AM
ronjenx's Avatar
This is from the FSM:
Theory of Operation
The State of Change (SOC) catalyst monitor uses the signals from both the upstream and downstream O2 sensors to detect aging of the catalyst. Based on the fact that when a catalyst ages, it loses some of its Oxygen Storage Capacity (OSC). As a result, part of the untreated exhaust gases can breakthrough the catalyst and causes the downstream O2 sensor to deviate from its neutral (Stoichiometric) position. By observing the activities in the downstream O2 signal, the degradation level of catalyst can be detected. In general, the higher the downstream O2 sensor SOC value, the more exhaust gas breakthrough and the lower the OSC of the catalytic converter.
When Monitored:
ECT above 70° C (158° F), engine RPM between 1400 and 2300, vehicle speed between 64 and 96 kph (40 and 60 mph), and engine run time greater than 3 minutes.
Set Condition:
If the final State of Change index is within the calibrated fail threshold. Two trip fault. Three good trips to turn off the MIL.
Possible Causes
O2 RETURN UPSTREAM CIRCUIT SHORTED TO GROUND
O2 RETURN DOWNSTREAM CIRCUIT SHORTED TO GROUND
O2 RETURN UPSTREAM CIRCUIT OPEN
O2 RETURN DOWNSTREAM CIRCUIT OPEN
EXHAUST LEAK
ENGINE MECHANICAL CONDITION
AGING O2 SENSOR
CATALYTIC CONVERTER
Old 01-19-2010, 05:14 AM
JK_Oman's Avatar
I will take it to the dealer to get it checked soon.
I've cleared the code yesterday and till now it didnt came again.
could it be a bad sensor?
i have the borla long tube headers on top of my list and as borla guys claims " it will be a code free enviroment and will gain from 18 to 24 HP".
Old 01-19-2010, 05:50 AM
ronjenx's Avatar
I had good performance gain with Borla headers on my '88 XJ.
Let us know what you actually see on your JK.
Old 08-28-2010, 08:21 PM
Jwilk's Avatar
Did you ever figure out what was causing p0430? I'm experiencing the same thing.
Old 08-28-2010, 09:00 PM
Steel Rain's Avatar
Work in progress!!
Old 09-03-2010, 09:01 PM
Jwilk's Avatar
Took mine into the dealer and it was the catalytic converter. It was covered under warranty.
Old 11-18-2010, 08:05 PM
74CJ5's Avatar
Just had this come up as well. How long is that warranty going to cover it? I just hit 54,000 miles.
Old 11-19-2010, 02:33 AM
dsp
dsp's Avatar
I think the emissions is for 70k.
Quick Reply: Code P0430 CATALYST EFFICIENCY (BANK 2)
