CONTINUOUS slave/master cylinder problems :(
Old Mar 25, 2013 | 06:00 PM
Lumppyc88's Avatar
Default CONTINUOUS slave/master cylinder problems :(
I have owned my jeep now for about 4 years and it has been great! except for the clutch system. I have problem after problem with my clutch going out. It happens very quickly... ill get in the jeep, turn it on and and my clutch pressure seems off and it is harder to put the jeep in gear. (By now, i know this is a bad sign) Usually by the end of the day, its completely out to where I cant put the car in gear at all. 4 times this has happened to me, 4 times ive replaced the master and slave cylinder, and its about to be 5. My Jeep is a 2008 and i don't even have 100K miles on it yet. I dont drive aggressively, I dont floor the peddle or speed shift. As bad as its been, I havent even been offroading in two years :( Any ideas as to why this continues to happen? and any recommendations on replacement parts that might keep this from happening?
Old Apr 5, 2013 | 06:10 PM
Marmot mb's Avatar
Sounds like you have debris in your fluid, they change the parts and top up the fluid.
Get the whole system flushed. Then replace the parts.
