Coolant Leak (engine area)
Thanks again for this post! The pictures were really helpful. I had the same issue. I was fearful that I might be getting in over my head when tearing it all down, as I was scared to death that it might leak when put back together.
I just took my time, and i did take the extra step of putting a paper thin layer of permatex around each water port only before bolting it down.
No leaks and its been a week!
Thanks for all of the detail and pics! 6 months after replacing the radiator, transmission cooler and thermostat, my son's top heater hose just blew. Removing/replacing all of that is over my skill level but at least I know the $$$ he'll be spending is required. Lotta labor...
Any updates on your LIM repair? I'm sitting at 234k miles and I think my time has come. Coolant was roughly 1gal low the other day and there's plenty of indicators around the motor that I need to replace some gaskets. If I'm using the part number you listed (68003427AB, updated to 68003427AC), it looks like I'll have valve cover gaskets included and those guys are a source of oil leakage for me. It was inner axle seals and brakes turned u-joints this past weekend....what's next?
For fuel injectors it's Mopar P/N: 4861667AA which I'm finding on Ebay for $80ea but I'm also seeing Bosch refurbished replacement injectors (Bosch P/N: 0280158119) which I believe are the original supplier for Mopar and able to get all 6 for $80. So I may go ahead and go that route replacing all 6 using the refurbed Bosch injectors.
Forgot to mention. They usually recommend to replace the Upper intake manifold gaskets while you're taking it apart as well. There's 6 of them, kind of like an O-ring gasket.(6) Upper intake manifold gaskets (4781580AA)
Here's a link to my step-by-step guide on replacing the LIM gasket if you haven't gotten it yet.
https://drive.google.com/file/d/1MJK...ew?usp=sharing
Also some pictures I took when doing mine which may be useful, where I had originally intended to put some of these pictures to the step-by-step guide but never got around to finishing it.
https://drive.google.com/drive/folde...oonXvgYPa-_-cF
Thanks for linking those numbers. If the injectors usually go around 130k then I'm definitely on borrowed time. I changed them on my TJ at 225k but that vehicle was cake to change them and they offered "upgraded" 4 hole injectors for more power, etc. I'll grab those o-rings as well since I'll already be in there, thank you for that. I have seen your LIM write up, it's sitting on my desktop now, reminding me that I've got to get that stuff ordered.
Thank you again buddy, I hope all else is well up north there with you and the family.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
I haven't ordered it yet, but there was a complete kit you linked that had this grommets (I'll get a part number if I can get the computer running). I was looking at Rock Auto for just the valve cover gaskets and grommets when I thought I'd be able to slide by like that and they were at that same price point for a (potentially) Spicer branded one, though under another name- and it included both gaskets. It "looks" like the Mopar valve cover gaskets are per side at $48 and no grommets as you mentioned. I need to just pull the trigger on my cart but man, the price of all those parts hurts. At least it's spring time though so it's not 20° in the garage when I'll be getting it all swapped out.
