Coolant line slight leak
Done and leaks fixed and they did not have to drop the diff.
Does anyone know the operating pressure of the transmission cooling loop? Most aux cooler installs don't remove the metal to rubber fitting - they cut one of the rubber sections in half and splice in with connectors and new rubber hose to extend to cooler. I assume the fancy hose ends were done due to worries about high pressure blowing off the hoses using clamps. Anyone know?
The new lines were $96 and labor was $165.
Have you tried calling other dealers in your area for other opinions?
Dealer charged $269.00...I bent over and took it
Ok, here's the scoop. Had the Jeep in the dealer today for some warranty work. The trans cooler lines were out of warranty. They quoted me $261 including parts&labor to replace the trans cooler lines which I got them to do because it snowed about a foot here today and may garage is cold and I got lazy and my Jeep was already there,yadda,yadda
ok i found a dealer that will do it for 300 CAN, but i want to do it my self. do i just get a OEM tube and replace it, or should i just hack it off and put some clamps on it??
