Coolant smell.
Old Mar 29, 2014 | 08:09 PM
HookEmHorns's Avatar
Default Interior Smell Once In A While
Not trying to hijack this thread or resurrect an old thread, but I have noticed that at times while driving I get a slight smell of coolant inside the cab... It doesn't last very long and it is random. Usually does happen when I have the heater on though, so I don't know if that is connected somehow, but I do notice a slight coolant smell. Anyone else experience this and get it figured out that could help me out a little bit?
Thanks
Ray
Old Mar 31, 2014 | 06:36 PM
Ryan0260's Avatar
Thanks
Ray
Have you looked around the water pump for seepage or corrosion?
Old Mar 31, 2014 | 06:39 PM
I haven't noticed any so far. It doesn't seem to be losing coolant either. At least not very noticeably.
Old Mar 31, 2014 | 07:46 PM
AuMinor's Avatar
I've had it happen in two trucks. One Ford & and a Chevy. Turned out to be the heater core both times. It took quite awhile before the leak was large enough to spot, though.
Old Mar 31, 2014 | 07:48 PM
ricci.beyers's Avatar
I have a 2103 JKUR with 17,800 miles. It was slowly loosing coolant, but I couldn't tell from where. (No smell inside though, however you could smell it from the outside). Anyway, took it to the dealer and they found a small leak in the radiator, between it and the a/c condenser.
Also, they found a leak in the thermostat housing. Replaced it too.
Hopefully no more leaks!!
OIIIIIIIO
Old Mar 31, 2014 | 07:51 PM
Thanks for the help guys. It's nothing terrible yet. But I would like to take care of it before it becomes a real problem. That gives me other things to check. Thanks again guys.
Ray
Old Apr 1, 2014 | 05:26 PM
inajeep's Avatar
Had a coolant smell for a long time. Never saw any puddles or anything. Eventually my temp started kicking up and the smell got worse. Ended up being a slow leaky water pump. Not serious but will eventually go. Went at about 95k miles.
Old Apr 1, 2014 | 05:44 PM
FDHog's Avatar
Ray
Summer heat is coming. Better get it straightened out now.
Old Aug 28, 2020 | 03:12 AM
Paul Amarante's Avatar
5 Year Member
Originally Posted by nicksabellajk
Hello everyone, does anyone experienced coolant smell when parking in garage after driving, and when parked with engine running and the fan comes on?
yep, I have a 2016 75th Anniversary Edition, Jeep actually swapped out the radiator at 20K miles, but low and behold still smell antifreeze after I go for a drive, it’s enraging, as soon as off warranty swapping radiator with a Mishimoto or other high end unit.
Old Aug 28, 2020 | 03:14 AM
5 Year Member
Originally Posted by ronjenx
Every once in a while I'll get a coolant smell around the Jeep. I think it's due to coolant vapor coming out of the coolant bottle vent.
yep, I think this is the reason, it’s a cheap plastic bottle and the cap is not really secure.
