Damn Water Pump
Old Aug 27, 2013 | 12:06 PM
FDHog's Avatar
Default Damn Water Pump
Just when I thought I was one of the lucky ones, no head problems, I start hearing the infamous chirp of a water pump. 7500 miles and my water pump is shot. Have to bring it in tomorrow so that they can confirm before they have to order the part. At least my dealer gives loaners. But come on, seriously, 7500 miles for a water pump bearing?
Old Aug 27, 2013 | 12:18 PM
Karnage541's Avatar
Atleast a water pump isn't to hard to replace.. if I'm correct. What year do you have?
Old Aug 27, 2013 | 12:22 PM
FDHog's Avatar
2013 JK Sport
Old Aug 27, 2013 | 03:19 PM
JK_hammer_47's Avatar
So many 2013 models with shitty water pumps. Should be a recall
Old Aug 27, 2013 | 03:25 PM
Karnage541's Avatar
I did read in the other water pump thread that there is a tsb on the water pumps.. not sure if its true or not. Ask your dealer.
Old Aug 27, 2013 | 05:44 PM
Jkjoe13's Avatar
I have a 13 JKU with only 10k and I just started hearing my chirp also! I love my jeep but come on chrysler!! This will be the second time in the 8 months I've owned my new jeep that it will be in the dealer for repair!
Old Aug 27, 2013 | 05:54 PM
fitzz47's Avatar
just had mine done today,make sure the right antifreeze is used HOAT for 2012 and OAT for 2013
Old Aug 27, 2013 | 08:19 PM
Jiblet's Avatar
And be aware, the new OAT formulation Chrysler is using does not have 2-EHA as did/does Dex-cool or other OAT formulations.
But I have read *unsubstantiated* statements that the new Chrysler OAT is the same as newer dexcool formulations. I'm not ready to believe that.
The (new) OAT gives good, long lasting protection but apparently the protective deposits may not form for up to 5000 miles. I'm suspicious that the early failure of the '13 water pumps may be due to early corrosion/cavitation for this reason.
Color is no longer a reliable indicator for coolant (and hasn't been for a while).
http://starparts.chrysler.com/newsle...r_Oct_2012.pdf
http://www.sae.org/mags/aei/mater/11284
Old Aug 28, 2013 | 07:00 AM
FDHog's Avatar
Went to dealer today. They took me without an appt and were going to fix it right there, except they didnt have a loaner for me.
Going in after the holiday weekend for replacement.
This was almost too easy.
Old Aug 28, 2013 | 02:28 PM
Legossey's Avatar
Yup my 2013 with 3500 miles on it started making a loud squealing noise when at full temperature. Took it in yesterday they called today and said it was water pump seal. They replaced the entire water pump and told me to come get it today. When I got there the manager said that was the 6th jeep this month he had to replace the water pump on.
