Sponsored by:
Sponsored by: DashLynx
Dash rattle?? Coming from Defroster area??
Old 03-19-2008, 08:20 PM
Omega Man's Avatar
Default Dash rattle?? Coming from Defroster area??
Ok, I have a new rattle and it is coming from the defroster area. It does it when the vehicle is cold. I have traced it to that part because I can make it stop by turning on the heat and blowing it out of the defroster for a little while.
It seems that once the "part" is heated the rattle stops. I think it might be a lose blend door or something close to it.
Has anyone experienced this or fixed this issue?
I already fixed the plastic thing on top of the wiper motor and this is not it.
Anyone?
Old 03-19-2008, 08:25 PM
amt97's Avatar
Anyone?
I'm at a loss if you've already fixed the metal piece that sits under the wipers. That's what mine is doing ... *rattle rattle* ... I need to take it apart and put some insulation there. I reached my arm out the window when it was rattling and pressed down on the outside panel and it stopped.
Old 03-19-2008, 11:49 PM
Voodoo's Avatar
I have smething similar:
At idle rpm there is a rattling coming from somewhere around the stereo/heating knob area. Was not yet able to identify the exact spot. (Always wear ear protections at the shooting range!)
Old 03-20-2008, 06:46 AM
rlabbott's Avatar
Default Hood Cowling
There was a thread on the Hood Cowl fix back some time... had good pics...
https://www.jk-forum.com/forums/stock-jk-tech-12/squeaking-dash-noise-cured-3743/
Sounds like you've determined it's inside however. I will add though that mine rattled less when hot, but it was the hood cowl heating up that stopped it. I did this fix and it worked for me.
Good luck!
Old 03-20-2008, 06:54 AM
Voodoo's Avatar
Mmmmm... gonna check that cowl anyhow!
Thanks for the input!
Old 03-20-2008, 07:13 AM
Stampsjk's Avatar
I have a rattle/noise coming from either defrost area or what sounds like behind the radio. It happens mostly when I am going driving over small bumps. I haven't messed with the cowl yet.
The noise I hear sounds like plastic parts rubbing together; ineterestingly it has gotten warmer in St. Louis the pat few days and I haven't heard it as much.
Old 03-20-2008, 07:33 AM
BaltChief's Avatar
I had a rattle behind my dash and found out it was a bottle cap.....yep, I had sat one on my dash while driving and it apparently fell behind the dash and was sliding around back there.
Old 03-20-2008, 09:49 AM
priell3's Avatar
I have that rattle that sounds like it is just behind the radio too. Hood cowl fix didn't work for me. I even removed the wipers, cowl and plastic piece and test drove it - still rattled. Still searching for the source. The cause could be someplace else, and the sound being transmitted to that area.
Old 03-20-2008, 08:01 PM
Omega Man's Avatar
This sounds like mine. I am thinking it is a blend door in the A/C unit. I can get it to stop making the noise if I turn it to defrost and turn the heat all the way up for a little while. I can then turn it back to a/c and change where the air comes out and there is not a rattle.
Just hoping someone had found a solution. I already did the cowl fix that was a good one.
Old 11-25-2008, 04:40 PM
jpp
jpp's Avatar
Reviving an old thread in hopes that someone has found the source of this noise. It's driving me nuts...
Quick Reply: Dash rattle?? Coming from Defroster area??
