Dead at 34K
#51
Originally Posted by youenjoyzedella
you've really gotta wonder what was done in the first 5K...
there was probably a reason why there was an almost new jeep with 5k on the lot.
#52
Catastrophic engine failure is unacceptable at that mileage. Kinda confused on the spun bearing/crashed valves thing. It's possible the bolts retaining the bottom bearing surface of the con rod failed?
#53
The common cause for a spun bearing on the JK's V6 is the motor burning excess quantities of oil due to bad rings and eventually emptying the sump leading to oil starvation to the pump & resultant loss of oil pressure to the bearings. However there have been a lot of "spun bearing" JK motor failures where there were no lubrication issues whatsoever (spun bearings result when the oil film on the bearing surface is broken due to a disruption in the oil supply to the oil galleries, causing the bearing to catch and spin in its shell, leading to rapid wear & destruction). I suspect one of those drunk/stoned workers has been using the wrong bolts on the bearing caps leading to the bolt loosening and either breaking causing sudden catastrophic engine failure as the rod lets go, or causing the bearing's shape to deform & then rapidly destroy itself. These bearings no longer have lead in them so are not as strong & resistant to wear as they once were.
#54
I had a BRAND spanking new transmission (non jeep and non-rebuild) go out after only 200 miles-- and it was truly catastrophic-- blowing a chunk on the side, welding the planetary gearset into a blob and threw fluid 30 YARDS in one direction and 10 in the other. Ol' Amco guy I first took it too gave me the sleil 'most people think its worse than it actually is...." I reminded him he said that when he tore it down
I had to actuallyeat the cost as I had also had a new rebuilt motor put in at 40 miles on the new transmission-- both shops pointing fingers at each other an no one wanting to do anything...........
Have 50 more stories from friends and family-- all the same: failure comes when it comes.
Nevertheless this OP's got lucky with the claim and I'm glad they're taking care of him.
#56
Dealer finished the repair today. Unfortunately, I'm at work in Alaska until next Friday, so it sits at the dealer for another week. Cause of the failure was a broken gear on the oil pump, and loss of pressure. Not sure why the low pressure light didn't come on? Curious...
#57
1 Post
#58
After typing this, I feel like I need to install an oil pressure gauge now. I scared myself, anyone got good pics for locations of added gauges?????
#59
So I wonder if there's a batch of bad Chinese oil pumps out there ticking away like time bombs? Chrysler used to make most of its motor components (exhaust manifolds, pistons & cranks, water pumps, oil pumps, etc) in-house at the Trenton engine plant prior to the Daimler takeover 12 or so years ago, when they then closed down the parts production section at the plant and started outsourcing most of the components other than the blocks & heads. Suddenly the 3.8L V6, which previously had a reputation of a reliable workhorse with an excellent record of being able to withstand abuse and lack of proper maintainance in its minivan applications, became notorious for cracked exhaust manifolds, seeping timing covers, noisey valvetrains, early failure of water pumps, excessive oil consumption and spun bearings.
#60
the 3.8 is only ''notorious'' to those who have had issues. the other 88% on the forum have had good luck with it. So far (knock on wood) I've got 65,000 miles, no issues. Almost all my mileage is a 75mph commute one hour each way to work.
