Death wobble
Old Jan 5, 2020 | 09:02 AM
dmalquist's Avatar
Default Death wobble
I have had the wobble before but the symptoms are different this time.
the wobble cab started by the following:
Cold morning starts
Braking while cold
Rough roads
I have had the tires balanced there is no loose movement at the track bar or drag link. There is a faint click when pushing up on the track bar.
I have a 3.5 lift and 35” tires. Tires are new ProComp
Last edited by dmalquist; Jan 6, 2020 at 08:21 AM. Reason: I submitted incomplete info
Old Jan 5, 2020 | 03:39 PM
resharp001's Avatar
Loved
Community Favorite
Have to guess that cold starts and braking when cold just has to be coincidence as they have nothing to do with wobbles. I'd test the ball joints if you are 100% certain that you have no play in the TB joints and that those bolts are torqued to spec (125 ft lbs). You should NOT be able to hear anything when pushing up on the TB. There shouldn't be any movement in that which you can make with your hand.
Old Jan 5, 2020 | 05:49 PM
LC Boyer's Avatar
Vet Army
Could be bad tires!
Old Jan 6, 2020 | 08:20 AM
dmalquist's Avatar
By cold starts I meant the tires are cold. The tires are new ProComp.
Old Jan 6, 2020 | 10:25 AM
Joe C's Avatar
Did the wobbles start with the new tires?
Old Jul 25, 2020 | 06:11 PM
Tim the first's Avatar
I have heard some chunky tyres can cause this wobble! Possibly play around with tyre pressures....?
