Death wobble on a stock suspension?
Am driving home from school and on the highway any time my jeep gets over 80 I get a horrible vibration ad wobble. Any one else have experience with this "safety feature", or know how to fix it. For now I am just going to recheck tire pressure
Based on your description, I'm not automatically convinced it's death wobble. Most people's first "death wobble" post describes a much more traumatic experience. Based on description alone, yours sounds like a tire out of balance. If it happens at a certain speed (you mentioned 80), I'd start backwards from tire pressure. Check tire pressure, confirm it's appropriate for the tire, and if your tires are stock, make sure you follow the recommendation on the driver's door. Then, you might want to have your tires balanced and your alignment checked, check for any work suspension components...
That's just a sign your about to go back in time. Usually happens around 81 mph.
Originally Posted by Steeperjeeper
I checked it to be 32psi all the way around but further down the road the track bar bracket welds broke and it fell off the axel which I think could have been my source of error.
ball joints and tire balance..check those first and all of the nuts and bolts on your front end, glad your ok.
it could have been just that your tb mount was going bad and providing slop until it failed completely
