a diff question
Old Dec 22, 2007 | 06:01 PM
jerzeyjeep's Avatar
Default a diff question
hey for you guys that change your own diff oil what is the perfered oil to replace it with and did you guys use a gasket to reseal it or rtv???
Old Dec 22, 2007 | 06:12 PM
CIJeep's Avatar
Do a search, I've seen it covered several times.
Old Dec 22, 2007 | 07:23 PM
armycop's Avatar
There is a magnetic drain plug on all Dana 44's and 30's on the JK. You don't have to crack the seal on the cover if you are just changing fluid. If you want to change the cover, then you can seal it with rtv.
I went with Royal Purple 75W 80
Old Dec 22, 2007 | 09:41 PM
BigJerm's Avatar
its in the manual in the back.
I believe the front D30 is less than 1 quart. 80w-90 and the rear D44 is 2 quarts 75W-140 if you are towing or other stressfull things. If you have the LSD you are supose to put an additive in also but most synthetics have the additive already in them
Old Dec 22, 2007 | 10:30 PM
SLICKWILL's Avatar
used rtv black works great!!!
Old Dec 22, 2007 | 10:45 PM
jerzeyjeep's Avatar
thanx slick i have to drain the fluid looks kinda milky and its leaking so here come the syn stuff and rtv
Old Dec 23, 2007 | 06:15 AM
Bob Coco's Avatar
Default You run 37" boggers with stock axles?
Those have got to be the most staining tire on any axle. I ran them on my YJ with ProRock 60's and still tore up axle u-joints. I can't believe you run 37"s without any breakage.
Bob C.
Old Dec 23, 2007 | 07:14 AM
TEEJ's Avatar
Talking
The synthetic oil doesn't have additive for the LSD in it already.....it has very few additives at all compared to the non-synthetics.
The reason it works is that the synthetic oil is much more slippery than the dino juice.
To clarify: LSD additive makes the LSD SLIP MORE, not less. IE: Leaving the additive OUT, makes the LSD work more like a locker. The MORE additive you add, the more wimpy the LSD will grip. The additives PURPOSE is to prevent chattering from too much locking.
We used to adjust the break-a-way torque on the LSD's that used additives, by using less and less additive, until we hit the point of diminishing return...the MOST lock up w/o chattering around corners, etc.
If planning on using the rig off road more than on road, leaving out the additive makes the rear work more like a locker.
Using synthetic oil is a great compromise, as it doesn't need any additives to allow some slip, but it allows more lock up torque to hang on before break-away is reached.
Old Dec 23, 2007 | 07:37 AM
jerzeyjeep's Avatar
why is there two different kinds of oil for front and rear??
Old Dec 23, 2007 | 07:39 AM
BigJerm's Avatar
well i guess we should go sue Royal Purple and Castrol then for false advertisement. It says on the bottle that the additive for LSD not needed because its already in the the fluid
