Do I need to be concerned with this?
Old Feb 16, 2010 | 12:04 PM
YOke's Avatar
Default Do I need to be concerned with this?
Happend to glance under the jeep from the drivers side door and saw this residue. Do I have a leak?
Old Feb 16, 2010 | 02:09 PM
Canada's Avatar
It looks to be some seepage from the TC. Its not terribly bad, but if your losing a lot of fluid (ie. seeing puddles) you would want to address this asap.
If you're still under warranty, let the techs deal with it.
Old Feb 16, 2010 | 03:24 PM
33 williys 77's Avatar
With the cold weather thing will loosen up , put a wench to the TFC bolts and keep an eye on fluid levels,
33
Old Feb 17, 2010 | 01:34 PM
YOke's Avatar
Ok, thanks,
I have an appointment tomorrow morning for the dealer to take a peek.
Old Feb 17, 2010 | 04:22 PM
Hellbound13's Avatar
Looks like it is seeping. Clean it off and keep an eye on it.
Old Feb 17, 2010 | 04:34 PM
goldtr8's Avatar
If its under warranty let them fix it. If its not under warranty clean it off and check the fluid level and keep an eye on it.
You can put a wrench on it but it most likely will not fix the problem. It will be either a leak at the rtv seal or porosity in the casting. This is my hypothesis from the pictures, but it could be something else.
Old Feb 18, 2010 | 02:26 AM
TINMAN080's Avatar
Your yoke seal is leaking on your transfer case. Not a major repair. They will pull the driveshaft, drain the case , pull the yoke and replace the drive-in seal.
Old Feb 18, 2010 | 07:56 AM
YOke's Avatar
It's in the shop right now...this is pretty much what they are doing. Thanks everyone for your diagnosis!
Old Feb 22, 2010 | 11:18 AM
YOke's Avatar
5 days later, I finally get my Jeep back....
Said if I would have to pay out of pocket, over $1000....
This is what they did:
"Removed t case asm completely dis assemble t case removing chain and planadays to clean case and reassembe t case and reseal complete t case asm also had to replace front prop shaft output snap ring and seal install and topp off fluid"
Yay warranty!
Yoke
Old Feb 22, 2010 | 11:22 AM
Locklain's Avatar
Yay warranty!
Yoke
Haha sounds like someone is milking warranty cash. At least they are being thorough.
