does hill decent work while under inflated?
Old May 22, 2015 | 03:24 PM
ohio79's Avatar
No blown fuses. We are planning another trip nxt Saturday so ill give it another go.
Sent from my SAMSUNG-SGH-I317 using JK-Forum
Old May 22, 2015 | 04:52 PM
Billbikes's Avatar
You need to be in 4lo, and you need to be locked in 1st gear. Tire pressure has nothing to do with the hill descent.
Old May 22, 2015 | 07:08 PM
Tooadvanced's Avatar
You don't need to be in 1st gear. Actually the way it works is 1st is 1mph. 2nd is 3 mph. 3rd is 3mph and so forth. Just an FYI
Old May 23, 2015 | 05:43 AM
ohio79's Avatar
I have an auto trans
Old May 23, 2015 | 05:51 AM
andrew putnam's Avatar
It worked for me last Saturday in drive (automatic) 20lbs tire pressure 4lo.
I'd check the fuse
Old May 23, 2015 | 09:57 AM
Dbird29's Avatar
Default 4Low only, section from owners manual
Hill Descent Control (HDC) – If Equipped
HDC is only intended for low speed off-road driving.
HDC maintains vehicle speed while descending hills in
off-road driving conditions by applying the brakes when
necessary.
The symbol indicates the status of the Hill
Descent Control (HDC) feature. The lamp will
be on solid when HDC is armed. HDC can only
be armed when the transfer case is in the “4WD
LOW” position and the vehicle speed is less then 30 mph
(48 km/h). If these conditions are not met while attempting
to use the HDC feature, the HDC indicator light will
flash on/off.
When enabled, HDC senses the terrain and activates
when the vehicle is descending a hill. HDC speed may be
adjusted by the driver to suit the driving conditions. The
speed corresponds to the transmission gear selected.
Gear Approximate HDC Set Speed
1st 1 mph (1.5 km/h)
2nd 2.5 mph (4 km/h)
3rd 4 mph (6.5 km/h)
4th 5.5 mph (9 km/h)
DRIVE 7.5 mph (12 km/h)
REVERSE 1 mph (1.5 km/h)
However, the driver can override HDC operation by
applying the brake to slow the vehicle down below the
HDC control speed. If more speed is desired during HDC
control, the accelerator pedal will increase vehicle speed
in the usual manner. When either the brake or the
accelerator is released, HDC will control the vehicle at the
original set speed.
