Dome light driver side
Hey guys!
I have a issue with the driver side. The dome light won’t come on, and the radio won’t shut when driver side door is open.
it works perfectly on the other doors..
so what do you think?
I have tried to jigg with the door cables in /out.. maybe fuse?
Y, I'd start with a thorough inspection of the wiring harness for the door since that is the easiest thing. Make sure none of the pins have backed out a bit. As the door opens, that wiring loom can stretch a little. If it's not that, I'd worry that it could be more the door latch itself. I think that is what ultimately sends the signal telling the jeep the door is open/closed. Since it sounds like this is specific to that single door, that is what makes the most sense to me.
