Door adjustments?
Door adjustments?
Hi, Got a brand new JK two door. The doors take a lot of force to close, and even open, pulling the latch from inside when it disengaged, it makes a pretty loud release sound and feel. It's working perfectly, but wondered if the dealer can adjust these to open/close a bit easier. I'm just worried something's gonna break or loosen by the amount of force needed to fully close them. Kids are 11 and 12, and have to try several times everytime they get in/out, slamming pretty hard to get them to not be "ajar". It's funny because prior I had a TJ, and used to tell them to quit slamming the door. That damn weld around the window is known to crack. So now they have to do the opposite..
Jeff Allan (10-16-2018)
The dealer can adjust it but be prepared to go behind them. I had them adjust doors on a 15 and after 3 weeks it wasn't any better than when I dropped it off. I picked it up and did my own adjustments. It closes nicer now. They aren't fond of warranty work.
Many of them are hard to close, because of the seals, including mine (yet it still leaks). Roll the window down just a bit and see if it is still tough to close. When I crack my window a bit it gets much easier to close. I just tell everyone to slam it like an old pick-up truck. When I open the door it pops open a coupe of inches without me pushing it.
You have multiple adjustment spots. The hinges on the door, hinges on the body, and the physical latch itself. I'd start with the latch and see what that does for you. It's only two bolts and they're easy to adjust and put back in place if necessary.
