Door hinge bushings are toast
Old Jun 24, 2011 | 07:38 AM
  #21
D_engel's Avatar
maybe some nylon washers/ inserts from a hardware store?
Old Jun 24, 2011 | 07:39 AM
  #22
Orangeav's Avatar
I'm with you Yeti, I really thought it was metal. I think it may have a plastic coating but the flange on top sure seems to be metal. I don't know though, I haven't bothered to really check it out.
Old Jun 24, 2011 | 07:40 AM
  #23
ronjenx's Avatar
Originally Posted by The_Yeti
Did you just tap the metal out and put in these plastic ones?
I haven't done that yet. I just cleaned and lubed them for now.
As soon as the Delrin rod stock arrives, I'll make new bushings, then find out what needs to be done to remove the worn bushings.
Old Jun 24, 2011 | 07:41 AM
  #24
BLK08JK's Avatar
I could be wrong on being just plastic then... mine were so torn apart I couldn't get them out the hinge fast enough! I didn't examine them too closely.
Jeeper posted pics earlier how to get them out... you can punch out from the bottom or if they are really messed up you can take a needle nose pliers from the top of the hinge and pick pieces out, that's what I had to do.
Old Jun 24, 2011 | 07:43 AM
  #25
The_Yeti's Avatar
I just aplied quite a bit of White Lithium Grease and they work fine it just makes a good mess because i dont use the door nuts.
Old Jun 24, 2011 | 07:48 AM
  #26
Odin's Avatar
Originally Posted by ronjenx
Mine appeared to be metal, lined with deteriorated plastic.
My right door makes clunking sounds when I "speed" over speedbumps. Retailer did something at 15000km service and it vent away, but now its back again.
Anyone?
Old Jun 24, 2011 | 07:51 AM
  #27
BLK08JK's Avatar
Anyone?
This is the exact reason I started the thread... without bushings my door makes clunking sounds over bumps. You can pull your doors off and check the condition of your bushings I guess.
Old Jun 24, 2011 | 07:53 AM
  #28
ronjenx's Avatar
Anyone?
Your clunk may be hinge related, but some plastic tape applied here usually fixes it, if the hinges are still good:
Old Jun 24, 2011 | 08:00 AM
  #29
jeeperjkjeeper's Avatar
here is the link to my original post
https://www.jk-forum.com/forums/show...ng-replacement
Old Jun 24, 2011 | 11:08 AM
  #30
BLK08JK's Avatar
Man, thank you Ronjenx!! This totally solved my problem, no more door clunk
God I love this forum!
