Door hinge problem...
Old Aug 21, 2008 | 04:41 AM
armycop's Avatar
Default Door hinge problem...
Last night when I put my doors back on, the passenger's side door wouldn't slide in the hinge very easily. I looked closer and found that the plastic looking insert in the hinge was cracked and preventing the pin from going in the hinge.
Does anyone have the part number or a cheap fix for this yet?
Old Aug 21, 2008 | 05:00 AM
racer83l's Avatar
I have a fix, leave the doors off..
I HOPE that Jeep has a part nuber for the insert and you dont need to buy a new hinge, but my guess, they dont.
Old Aug 21, 2008 | 06:28 AM
armycop's Avatar
I may take it in to the dealer under warranty. I was just wondering if someone here has a cheap fix to save me some time.
Old Aug 21, 2008 | 06:30 AM
BaltChief's Avatar
If you find out let us know. Mine are cracked too so I may have a problem when the day comes to put mine back on.
Old Aug 21, 2008 | 07:33 AM
MOWrangler's Avatar
I had that problem too... I just pushed down harder until they seated. I guess I'll have to look at that closer next time I put my full doors back on.
Old Aug 26, 2008 | 03:50 PM
mdantonio's Avatar
Hi Guy,
I'm not sure if it would be beneficial to find a drill bit VERY close to the plastics bore size and slightly enlarge the bore. I would be very cautious about bit selection because if you oversize just a tad too much it'll rattle. Maybe a better solution would be to take some plumbers pipe cleaning tape and polish the pins first? This would remove trace amounts of rust and ever-so-slightly reduce its diameter. Your Jeep...your choices. These are only suggestions. Good luck! Take care... Mike
Old Aug 26, 2008 | 04:00 PM
07JKRUBI's Avatar
I have the same problem, if I put the doors on wide open they will not seat, if I put then in place with the door at about a 45 degree angle they drop right in. I hope this makes sence.
Old Jul 5, 2011 | 06:08 AM
mecheng10's Avatar
Default Replacement Bushings
Magnitude Engineering offers replacements bushings for Jeep Wrangler JK door hinges.
http://www.magnitude-engineering.com/products.html
Old Aug 1, 2011 | 06:33 AM
bripsu's Avatar
+1 on the Magnitude Engineering. Still a bit expensive for what they are, but much less expensive and durable than the Mopar replacement. Check your door pins too, mine were still sticking with the MagEng sleeves and I noticed the pins were corroded. I took a Dremel wire wheel to them and put a coat of white lithium on them, now its as smooth as silk.
