Door hinge thread
Originally Posted by kevinlee
If you insist on fixing the hinge you can buy hinge pins https://www.4wheelparts.com/p/crown-...KMN-55395702AE
Maybe since some people are on this thread you can help with some replacement part names?
These two black flex hoses I need both plastic pieces that hold it correctly. That stuff snapped as soon as I changed the plugs for the first time.
Also which bump stops do I need to replace these teraflex? Do they screw in or pressure fit? Should I also buy the crown auto or omix replacement factory front upper bumpstops?
https://www.quadratec.com/products/1...QaAg9gEALw_wcB
Just shoves up and in, although you'd probably have to remove that spring and dig out the broken part still wedged up in the cavity.
Chrysler should be held responsible for the aluminum to steel issue. Everyone’s hinges are rusting. Who did that in the first place was probably fired but it should be a voluntarily recall for owners...
seriously they should be held accountable. Wonder if any law suit can be filed but they most likely covered that in there warranty specs.
thats most likely because they painted and just put the aluminum back touching the steel. Now they put spacers between it so it doesn’t happen.
