door removal
Old Jul 6, 2011 | 05:51 PM
  #31
sclan's Avatar
Originally Posted by jon4pres
I tried the wd-40 and all the wiggling and pulling that I could handle and got no results.
Where did you stick the jack?
I haven't had to do this, but if it were me:
I would have a second hand to operate the jack cause I would be holding the door out at a 90* angle.
Put a block of wood on the jack to prevent damage to the bottom of the door.
Old Jul 7, 2011 | 06:06 AM
  #32
nathanmares's Avatar
I still have the running boards that mine came with (is that what you call them). I placed the jack on them and cranked it up. I watched to make sure I only lifted the door about half way then lowered it sprayed it and pulled them off. I did put a rolled up towel on the jack to prevent damage directly to the door.
I would guess if you have some cinder blocks or some wood to put your jack on it would be much easier.
I rolled up towel on the bottom of the door helps also when trying to pull the doors off if they are stuck, really saves your hand.
