E-brake not holding
Old Dec 23, 2013 | 10:59 AM
Arctic Blue's Avatar
Originally Posted by offroadtimmy
Not trying to sound stupid but is my parking brake supposed to hold on a hill or are the stock tires on my rubicon JKU to large like the dealer says?
I have to pull it up all the way. It won't hold on the slightest hill. At all. The dealer said that's how it is from the factory. I am having a real hard time believing him.
Originally Posted by Rob 12B1P
Mine wont hold on its own either, has to be in park or it will roll on a modest incline.
Originally Posted by S-Thing
My parking Brake does not hold well and I consider it to be a safety issue. Hopefully someone here has a solution.
I have to park in 1st or R (obviously a good practice) and pull hard on the handbrake to hold on my 2012 JKU from rolling down my slightly steeper than typical driveway. (brake + 2nd will not hold) Took it to the dealer and they replaced part of the handbrake lever mechanism that was bent. It held a little better for about a week (more positive "clicks", smoother) but then reverted to the pre-"fix" state. I followed up with the dealer and they said "that is how jeep build it" and the brake was "working properly". They also said to aggressively set the handbrake... in my case means pull until it feels like something is going to bend or brake.
Searching here some it seems hit-or-miss with brake adjustment. There is a short thread talking about adding a reinforcement plate to the handbrake ratchet mechanism. I may try that after I run out of warranty. .
-Jim
You guys, I had the exact same thing happen with my 2012 e-brake just a couple of weeks ago. The dealership told me that the Giant spring on the handle for the e brake was broken. And that is why even with pulling the handle all the way up as far as it can go, the e-brake would not hold anything. Not even on the incline to my own driveway which is as little of a grade as humanly possible. I took it in and they replaced it under warranty. I feel like it is starting to lose it tightness for lack of a better term and the dealership is checking it out again. I don't have the Jeep back yet, should hopefully be later today or later in the week after Christmas. I will update you more later. If you want to PM me go right ahead!
Sent from my HP 7 using Tapatalk
Old Dec 23, 2013 | 11:00 AM
Mark Doiron's Avatar
Originally Posted by jeeperjkjeeper
I can't figure mine out either....sometimes I can pull all the up and it doesn't hold worth crap and other times it really holds great at 3-4 clicks...wtf?
Try some brake cleaner on the e-brake handle pivot point.
Old Dec 23, 2013 | 11:06 AM
Originally Posted by Cjsmith4
Mine used to hold really well...until I stared using it to hold the jeep on steep hills when I was wheelin. Think I wore it out. And now it won't hold at all on even the smallest hill. Just use the gears now.
This is my situation. But it is unnerving. I've had my Jeep start to roll in first gear on especially steep inclines--my oldest daughter's driveway, for one. When that steep incline has a 1600' cliff on one side and a memorial plaque for a guy who died there on the other, it is downright scary. I really want a fix for this.
Old Dec 23, 2013 | 11:17 AM
Cjsmith4's Avatar
Mine does the same thing at my moms when left in first. Bottom of her driveway is trees. I don't really wanna come out and see the jeep parked in the trees so I put it in 4-lo when parking on an incline. I do this anywhere now that I feel at all uneasy. 4-lo holds it well.
When off-road on steep hills, I also use the added security of a nice size rock behind the wheels. Makes me feel better.
Old Dec 23, 2013 | 11:37 AM
You need to replace the handle assembly AND tighten star wheel guys
Old Dec 23, 2013 | 11:57 AM
jnabird333's Avatar
If you have been in the mud I would HIGHLY recommend taking the rotor/drum off and cleaning everything. When mine began to not work so well I found the whole thing to be packed with dried mud.
Also, contrary to many beliefs they so not automatically adjust. This needs done manually and often. I usually give a few clicks on the star-wheel with each oil change.
Mind you: the e-brake isn't what I would call robust but it should hold your Jeep at an incline sufficiently.
Old Dec 23, 2013 | 12:25 PM
ronjenx's Avatar
Yours may indeed be like that from the factory, but that doesn't make it right.
Mine grabs well on the 4th click, and on a steeper hill I may have to go one more click.
All I have done to mine is adjust the shoes with the star wheel, and keep the clutch spring clean with brake cleaner.
If the tension spring on yours is broken, it will not get a fresh grab on the cable drum each time the lever is pushed down.
See this thread to get an idea how the lever works and some of the parts' names. https://www.jk-forum.com/forums/stoc...-study-135255/
Old Dec 23, 2013 | 03:53 PM
FDHog's Avatar
When you park facing uphill put it in 1st gear. When you park facing downhill put it in reverse. Should hold better.
Old Dec 23, 2013 | 04:06 PM
offroadtimmy's Avatar
I had it at the dealer this AM because I have been bitching about it since I bought the jeep 2 months ago. They said they adjusted it as far as it would go and it would adjust itself as I back up. So I left because I'm angry and think he is a moron. 1st place I park on a slight incline, it won't hold at all. Been out all day and the same thing every where I park. Just got home and parked in the driveway, ( small hill ) it would only go up 3 clicks and held. WTF is that all about?
Old Dec 23, 2013 | 04:47 PM
kjeeper10's Avatar
Vet Army
Mine is the same. Dealer did something but did not last long. The parking brake on the jk is garbage. I've since replaced the rotors and gave up adjusting the brakes. I will give it another go when the weather gets better. Until then I keep a $8 harbor freight chuck in the rear
