Electrical gremlins
I have a 2013 JKU and since day one it's had annoying electrical gremlins.
The problem: interior and exterior lights display a faint flicker when engine is running, flicker gets brighter and noticeable in cold weather or when accelerating. Sometimes, when accelerating out of my driveway (cold weather only), the radio will shut off momentarily and come back on. And still, the flicker is noticeable.
I immediately thought battery or alternator but those seemingly checked out fine. Is it a bad ground? How do I even begin to search for that?
Thanks all!
Thanks all!
My guess is with the lights dimming and the intermittent power interruptions that you have a bad connection or corrosion at a connection causing the problems you could also have a bad battery. Finding the problem is going to be a pain in the ass as most electrical problems are. I personally would start with the battery and replace it with a known good one then check and clean the battery connections.
