Engine a bit "thrashy" sounding on startup
Old Jul 27, 2010 | 07:59 AM
OpenTrackRacer's Avatar
Default Engine a bit "thrashy" sounding on startup
I've noticed that the engine on my new (to me) 2007 Wrangler sounds a bit "thrashy" on startup. I was wondering if this was normal for the 3.8 liter or a cause for further investigation?
Thanks!
Old Jul 27, 2010 | 01:08 PM
JKlad's Avatar
Thanks!
If it happens for the first few seconds (especially when cold & the Jeep's been sitting for a while) & then goes away quickly, then it's probably the anti drain-back valve on the oil filter allowing it to empty. There's been quite a few threads here about certain brands of filter being worse in this regard than others. Mine only does it if it's been sitting for a few weeks (Mopar filter), but yeah I agree it sounds kinda scary if you don't know what it is, & you half expect a piston to come flying out through the hood!
Old Jul 27, 2010 | 01:27 PM
It seems like it happens after it's been sitting overnight or longer. It doesn't sound like the engine is going to fall apart, just rough. It only lasts for a second or two.
Old Jul 27, 2010 | 01:37 PM
JKlad's Avatar
Yeah, sounds like the drainback valve then. Here's a thread with some info on different filters...
https://www.jk-forum.com/forums/show...ght=oil+filter
