JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Engine Sputter/Stall (https://www.jk-forum.com/forums/stock-jk-tech-12/engine-sputter-stall-221423/)
CFonda Mar 4, 2012 04:28 PM
Quick question everyone - while driving home tonight, my '07 JK 6 Speed had some issues. I stopped at a light, and immediately noticed that my engine had started sputtering. The RPM's would drop and then jump back up to normal. I stopped at a second light and the sputtering continued. A third light at an incline and the sputtering lead to a stall. The only way I could stave off the effects was to keep on the gas at a light and keep the RPM's above 1000.
I had a post about this a while ago, but the symptoms disappeared right away. Any thoughts? Dirty throttle body? spark plug issues? fuel filter?
Any help would be greatly appreciated.
Thanks!!: usa :
CFonda Mar 5, 2012 03:50 AM
Bump for new ideas?
gpmech7 Mar 5, 2012 04:08 AM
Need a lil more info to make it accurate - my guess....crankshaft position sensor could be messed up
CFonda Mar 5, 2012 06:22 AM
So I just cleaned the throttle body, put a new air filter in, and put through some Lucas Fuel System Cleaner. No change in results.
It's just fighting to idle - bounces off of about 500 RPM's and is very rough. No idea what I could be looking at.
Rule18 Mar 5, 2012 06:28 AM
Are you using a tuner? I had a problem just like yours which turned out to be computer-related due to wrong info programmed into the tuner by Hypertech, nothing was physically wrong with a part. If you're not using a tuner you might need to go to your friendly neighborhood stealer to have them check it out...:doh:
Ryan0260 Mar 5, 2012 06:40 AM
How does it run at higher rpms?
CFonda Mar 5, 2012 08:40 AM
Nope - no tuner. Have since got the ETC warning light coming on. At a repair shop now since I was stumped :(
Runs okay at high RPMs - hopefully its just something computer related that needs a flash.
tattedfire Mar 5, 2012 05:00 PM
Let us know what they say and if the problem gets resolved
Lone Star JK Mar 5, 2012 06:04 PM
Thanks!!: usa :
I had same issue ended up being a bad egr.
CFonda Mar 6, 2012 04:05 AM
Resolution
So the final diagnosis is a bad Throttle Body / Throttle Body Actuator.
No good at all.
© 2026 MH Sub I, LLC dba Internet Brands
