Engine wont start after rollover.
I recently rolled my jk, and it was left and its side for a few hours before i managed to get assistance in rolling back over. Now there is no power what so ever, and it obviously wont start. Does anyone know what I need to do to get it operational? I am assuming all fluids need to be changed, but not sure what else could be wrong. Is there an auto lockout when a jk rolls as a safety mechanism?
If you did not pull the plugs before trying to start it there is a strong chance you bent a few valves after oil seeped into the cylinders. Try pulling the plugs now and see if the engine will even turn over.
If you pull the plugs nothing bad will happen (if there is any resedual oil in the cylenders it may blow all over the place so stuff a rag in each plug hole) the battery could have gone bad but my guess is no.
Good luck
Also try disconnecting the ground for a few minutes.
Test the battery to confirm it is good (auto parts store)
If it turns over you may be OK, if it will not even turn over and the battery/starter/electronics are OK then you are toast....go see a mechanic/call your insurance company. If the Engine is blown because of the roll over you should have coverage
