Esp wtf?
ok so i've had the jk about 3 months or so and for the first time last week my esp light came on on an on-ramp didnt think anything of it until i went up the same ramp today and it went off again seems to be the only place it ever went off any reasons ...... oil , pitch of the road,
o BTW normal on-ramp speeds and the tires were rotated between ESP lights
there has been a thousand comments about this, usually with people who have lifted their jeep and/or lifted their rig, which i notice you are having done....when you do get those things done i believe you can take it to the dealer and have them permanently disable the ESP or you can install a toggle switch to shut it completely off and on as needed (plenty of writeups on here for that as well)....all that being said i have a stock setup and i have noticed that mine will do this every now and then and it will always turn out that one of my tires is low on air...fill'r up and no more problems, so i would check that out and see if the problem goes away.....
It happened on mine and its very easy to fix 10 minutes tops ...
here is a write-up .... even on not lifted jeeps some times the steering wheel is not centered (from factory) an the esp activates when is not needed ...hope this helps
http://project-jk.com/jeep-jk-write-...-end-alignment
Mine has been doing this since new, had it serviced last week (1st service) and told the dealer about it. They checked and said I had the new module so it should not be doing it (there is a TSB on older JK for this). They then told me the only solution is to deactivate the ESP altogether but should they do that I cold never get it back. Still haven’t decided what to do.
I can't say for certain that improper tire pressure took care of this for me, but after lifting I had an ESP light at one particular off-ramp. 100% reproducible. Futzed with steering wheel and it didn't go away. I also had new tires and the installer pumped them up into the mid-40s. I brought the pressure down to a recommended 30 psi, and also upgraded the JK firmware with the Hypertech, and now the ESP light at that off-ramp doesn't come on unless I'm exiting it stupid/crazy fast (it's a tight, 180 degree turn). Bottom line: Check your tire pressures.
