Factory lug pattern? Need help quick
Old Nov 26, 2010 | 02:26 PM
maine07jk's Avatar
Default Factory lug pattern? Need help quick
I couldn't find this right off the bat and need the lug pattern and rim width to sell my factory wheels and tires. My factory wheels were the plain old aluminum with 225/75/16 tires. They guy wanting to buy my rims has a 2001 Jeep grand Cherokee and his say 5 lug, 127 mm rim. Are mine the same mm or 114mm? What is the difference and will they fit his Cherokee?
Old Nov 26, 2010 | 02:33 PM
jdubb75's Avatar
The lug pattern is 5 on 5". Not sure on the stock 16" wheel width.
Old Nov 26, 2010 | 02:41 PM
nthinuf's Avatar
5x5 is the same as 5x127mm (and yes, JK's and newer cherokee's use the same pattern)
The FAQ's at the top of this modified area have lots of info...
Q: What are all the factory wheels that are available for the JK?
A:Factory wheel type and sizes listed below:
X Standard
Painted Steel - Size 16 x 7.0
X Optional
Painted Cast-Aluminum - Size 16 x 7.0 (2007)
Painted Cast-Aluminum - Size 17 x 7.5 (2008)
Sahara Standard
Sahara Optional
Painted Cast-Aluminum - Size 18 x 7.5
Rubicon Standard
Machined Cast-Aluminum - Size 17 x 7.5
Backspacing on all factory wheels is 6.25"
Old Nov 26, 2010 | 02:44 PM
ingramJK's Avatar
If all you need now is your rim width, open your drivers door and check the sticker on the frame. It says the wheel specs that it came equipped with.
Old Nov 26, 2010 | 03:02 PM
maine07jk's Avatar
Good deal. Thanks guys!
