Floppy hood
LOL When you dish it out you gotta be able to take it. Believe me, I dish it out so it always comes back.
And in regards to the hood fix I did. Yes it is simple and yes it does work. I commute about 150 miles a day round trip for work and every chance I get my foot is on the floor. I do 80 to 95 alot. My house is also located in what at times seems like a wind tunnel. (not the Dave Despain kind) My hood is S O L I D !!! No Lift. I know there are some other things guys have done on here that are pretty trick and some are down right difficult but I'm all about simple and to the point. It works try it. What do you have to lose, $5 and maybe 10 minutes?
I was just looking at an '08 tonight and it appears the seal under the hood may be more robust than it appears inthe pictures of the mod. Can anyone with an '08 commenton whether they've seen this problem or not?
I had this problem also and noticed it got alot worse when I removed the plastic air dam. I removed the spring and it completely fixed the problem. Hood is solid now but I rarely go over 75mph.
Thanks again for your solution Clackey. Also, thanks James76 and Amt96 for explaining the TSB. I'll let you all know how the solution works when I try it!
Gotta' get that done soon, before my hood takes flight!! It's Gotta' be hard on that poor little wimpy looking safety catch.
I'm also wondering if anyone will offer heavier latch rubber links?
Thanks for the offer, but I won't make or sell a set for liability reasons.
I over-engineered them, but God forbid something should fail and someone get hurt or worse, killed, because of it. I could handle it myself, but would not want to have several sets out there to worry about.
Also, i have to have the jeep to do a proper fit, and the bottom bracket gets cannabilized in the process. I can and will, however, provide details for educational purposes if some one wants them....
