fluid change
The transfer case already has synthetic ATF+4 in it.
Be careful what you use in your 6 speed. I tried some synthetic in my Dakota's manual transmission back when it was a year or so old. The synchros didn't like it at all. Went back to the MOPAR stuff, and it went back to normal.
Originally Posted by harmonsjeep
has anyone changed the front end/ transmission / transfer case and rear end to synthetic? if so what kind of fluid and how many quarts
Royal purple 75 w 90 in the d30 and d44, 1.25 qts approximately in the front. About 2.25 approximately in the rear.
Pennzoil synchromesh in the NSG 370. Roughly 2.5 qts
And Atf 4 in the t-case. Roughly 2 qts
Last change on the t-case at 30k and it looked brand new still, weird
Im running Mobil 1 in the 3.8, 6 qts
Originally Posted by JKlad
How are you finding the Penzoil in the tranny compared to the MOPAR fluid? I'd be interested to know if it's smoothed the shifts out (particularly the infamous 2nd gear crunch) or made any other noticable improvement in performance over the OEM fluid.
