Fluid and "stuff" under engine.
Old May 28, 2011 | 07:57 AM
sbierman's Avatar
Default Fluid and "stuff" under engine.
UPDATE: it was the water pump.END UPDATE
Can someone help me identify what is going on here? This is a 2008 Wrangler X.
Old May 28, 2011 | 09:48 AM
bowerss2's Avatar
i am afraid you have aluminum mold...
Old May 28, 2011 | 09:53 AM
Jae Suite's Avatar
Looks like a water/oil mix, check your dipstick see if it's overfilled with like a coffee colored substance
Old May 28, 2011 | 10:05 AM
sbierman's Avatar
My oil is clean, just changed it in fact. Now, it could be leftover from the previous owner. It was there the last time I changed the oil, too.
Also, there is a red fluid leaking there, too. Is this power steering fluid?
Old May 28, 2011 | 10:06 AM
bowerss2's Avatar
in all seriousness this is exactly what it looks like.
Old May 28, 2011 | 10:18 AM
mkjeep's Avatar
Almost looks like your power steer resevoir may be leaking and blowing it back into that spot. Can you wipe that brown gunk off? I suggest clean it up and you may be able to tell more where its coming from. You have trans lines runnin on the opposite side of the engine, maybe one is leaking and is running around to that side? Most likely the power sterring reservoir, the red stuff looks like atf-4. Maybe there's a small leak at your oil pan and thats mixing with the atf blowing on there an causing a brown gunk. Along with a coolant leak mixing with oil.Check out those things.
Old May 28, 2011 | 10:21 AM
mkjeep's Avatar
I agree, but if the oil in the engine is ok, some kind of water/oil mixture is getting there some way.
Old May 28, 2011 | 10:22 AM
rinkishJK's Avatar
Maybe the power steering pump is leaking and its running down. It's def atf from the looks.
Old May 28, 2011 | 10:23 AM
Jedi Knight's Avatar
Mine looked like that when my water pump was going up and leaking coolant. Check out coolant level.
Old May 29, 2011 | 05:03 PM
mkjeep's Avatar
Your right, Most likely a leaky waterpump caused most of the residue, but he also needs to check the power steering pump reservior/tranny lines aswell, that bright red is not pink coolant.
My water pump went out at about 20,000 miles.
