Flywheel position HELP
Im replacing my clutch and Flywheel.. I took off the Flywheel and forgot to check the position it was in for the senser... Damit!!!
Is there anyway to make sure its in the proper position???
Originally Posted by carolinajk
there should be a locating dowel i bet it fell out or came out with the flywheel , just look for the small hole and line it up with the small hole in the crank you will be fine
