Front Caliper Bolts
Old Nov 28, 2010 | 02:48 PM
JKRockStomper's Avatar
Default Front Caliper Bolts
Does anyone know the part number for the front caliper bolts?
I am need of replacing them since they have sheared off while driving. I was able to get her home safely but it could have been worse.
Old Nov 28, 2010 | 02:52 PM
mkjeep's Avatar
Holy shit! Glad your ok. Ronjenx should know, he's the Encyclopedia Jkanicca.
Old Nov 28, 2010 | 02:58 PM
ronjenx's Avatar
The front caliper bolts, that hold the caliper adapter on, are:
68004084AA
M14x1.50x40.00
Please share the circumstances of the bolts shearing off. That is serious stuff we all want to avoid.
Old Nov 28, 2010 | 03:10 PM
nothing to report on how they sheared off. I have not had the brakes serviced for many thousands of miles and just got back from a three hour drive.
Rear Caliper Locating Pin Set
2007-2010 Jeep (See More Info)
Part # 68003777AA
is the parts that sheared off?
Old Nov 28, 2010 | 03:13 PM
ronjenx's Avatar
So, are you referring to bolts, or the "chromed" pins the caliper slides on?
The pins are 68003706AA, PIN KIT, Disc Brake
Old Nov 28, 2010 | 03:19 PM
from what I can see without taking everything off tonight is that the pins sheared off. The caliper is floating free inside the wheel.
Old Nov 28, 2010 | 03:24 PM
ronjenx's Avatar
Can't help you until you actually see what's going on.
Since you posted rear brake part numbers, I'm not even sure if it's the front or rear brakes you are having problems with.
Old Nov 28, 2010 | 03:32 PM
it is the front, Part # 68003706AA, pins. The pins are able to slide out with the hand there is nothing holding them in.
