Front d30 axle problems !!!
Allright well I am going to make this short
@ 1400 miles I had a new front D30 axle put in was leaking @ the diff and axle tube !
Replaced under warranty everything is great yeaaaaaa
Then for the last 3 weeks I have been getting a whining noise that is very loud
@ higher speeds! Put on lift @ work today to change oil after having @ dealership for 2 full days and they didn't hear any noise and I told them to check the front axle something isn't right. Well after changing my oil low and behold to find diff fluid leaking again from the front diff @ the pinion on the diff
at the front drive shaft
Could the gear mesh in the new axle be bad and causing problems such as
low gas mileage?
vibrations in the drivetrain?
leaking fluid ?
Please someone help and should I ask jeep to put a D44 in the front becasuse
apparently there is someting really wrong here!!!
low gas mileage?
leaking fluid ?
Dunno they wouldn't tell me I would assume that they transfered all internals over I asked when I called this morning and ran the service managers tail over the phone but wouldn't tell me what exactly they did but the print out say new housing's axle and diff
You have any ideas???
Sounds like you got a new carrier and tubes (thats a good thing, fresh straight C's for you to gusset!). I would have them overhaul it, it honestly sounds like they didn't set it correctly.
EDIT: Just for clarification, they probably transfered all your internals into the new carrier assembly (center section, tubes, C's).
I am just wondering if there is something seriously wrong with the D30 axle
I don't won't to go back with it again if they keep replacing it every 3000 miles
Location: Hangin in the sunshine state....staging forum..
low gas mileage?
leaking fluid ?
low gas mileage?
leaking fluid ?
here is a write up about setting up gears, its long but a good read so you know whats going on there.
https://www.jk-forum.com/forums/jk-write-ups-39/gearing-82262/
Good luck maybe try another dealer if the original is still unhelpful
Thanks 4 the info everyone I appriciate it alot I guess I just got the bum mechanic and dealership to deal with
I am taking it to another dealership in my area b/c they are a little more offroad friendly and the dealership that had it the last 2 days couldn't warrant
anything they did wrong nor even really tried kept blaming it on the lift and the fact that I have "Big mud tires" which they couldn't hear over to hear the noise I was describing to them
