Front DS - Anyone know what this little ring is???
Old Nov 27, 2012 | 05:48 PM
dave nelson's Avatar
Originally Posted by TINMAN080
Replace the clamp with a new OEM one. You'll need a set of clamping pliers to clamp it tight. If you use a large screw-type clamp, it will cause a little imbalance in your shaft.
Alright, I just picked up a clamp that appears to be exactly like the OEM one. I showed the pictures to a mechanic, and he said that the rubber ring that the clamp goes on is actually just for rotational balancing, not for sealing the CV joint or anything. I don't see any evidence of leakage anywhere on the boot, so it looks like it should be fine for now.
Thanks again guys!
