Front fender flare clips
I am looking for a definitive answer on the correct clip for the front fenders on a 2008 JK. The diagram I have seen online does not make it clear if the same clip is used all the way around the fender or if there are different types in different locations. I have a recurring issue with car washes ripping off the front right flare corner and they usually just replace the corner clip but this time I'm going to pull the fender flare completely and reinstall with new hardware and see if that helps.
I'd appreciate an answer to:
1. Are all the clips all the way around the fender flare the same?
and
2. What is the correct Mopar part number. I'm seeing 68039280AA or the aftermarket 20887.
Thank you.
and
Thank you.
There are pictures in the attached thread and I don't recall if I also put in pn's.
http://www.jkfreaks.com/forums/showt...r-Fender-Flare
There are two different clips. These are the ones I have bought several times. (on my 4th set of stock flares)
clipsandfasteners.com
A20887 - box of 15 - $9.02
A11146 - box of 25 - $3.18
