Front/Rear track bar
Front/Rear track bar - Newbie questions
What are they for? I'm trying to better understand the differences in the plethora of suspensions out there. What exactly are the track bars for? What role do they play in the suspension?
Track bars (sometimes called panhard rods) keep the axle from moving laterally (side-to-side). They do "track" somewhat in an arc as the suspension moves up and down, but without it your axle would move around significantly.
edited to say Redegade beat me to it.
I am sure there is a better explanation. But basically:
You have control arms that allow the vehicle to move up and down but NOT move forward and backward (stays above the axles). You have track bars to allow the vehicle to move up and down but NOT move side to side.
So where does it connect to? Does the track bar connect to each end of the axle? How exactly does it prevent the axle from shifting side to side. I notice the bend, so maybe it connects to the frame somewhere to the right of the differential and then connects to one end of the axle?
[IMG][/IMG]
Awesome. So i'm deducing that an adjustable trackbar is advantageous for lifted suspensions because you can adjust for the difference in length between that mount point and the axle, as compared to a stock trackbar. How do they adjust? By twisting or some sort of locking mechanism?
Edit..thanks for that pic....And thanks everyone for the edumacation!
Ok, here's another question. Where does the sway bar come into play here. The way bar keeps from body flexing from side to side correct? What does the electronic swaybar disconnect really provide? I guess I don't see what the advantage of having that is.
