Half Door Kit Availability
#352
I want to keep my full doors completely intact so I can easily switch between full and half doors.
#353
I removed all the tape, pulled the unneeded pins, wires, and connectors, and then reassembled this harness. This way I don't have the two extra unneeded connectors floating inside the door. If I ever open the passenger side door for some reason, I'll probably repeat the process on the passenger side too.
#354
Anyone have all the latch and harness part numbers/prices to convert to power locks for the Unlimited?
Front Left Latch:
Front Right Latch:
Rear Left Latch:
Rear Right Latch:
Front left Harness:
Front Right Harness:
Rear Left Harness:
Rear Right Harness:
Thanks in advance!
-Jeff
Front Left Latch:
Front Right Latch:
Rear Left Latch:
Rear Right Latch:
Front left Harness:
Rear Left Harness:
Rear Right Harness:
Thanks in advance!
-Jeff
https://www.jk-forum.com/forums/show...=1#post1775542
These are the parts for the front. Harnesses list for about $30 each and the latches list for about $85 each (I think).
#356
I used 55077966-AH and 55077967-AF. List is about $125 each. You'll need four bolts too. Part # is 6508775-AA, list is about $6 each. Keep in mind that you shouldn't have to pay list for any of this stuff.
#358
Did you purchase these?? Is this # and $$ for just the Plastic Housing or does it include the Glass also??
#359
Yep, they're on my Jeep. Those part numbers Include everything that is needed--foam seals, plastic housings, and mirror glass--completely assembled too.
