View Poll Results: Which hoist do you like the best
Harken Hoister
10
58.82%
Top Cap EZ Lift
0
0%
Hoist-a-Top
7
41.18%
Voters: 17. You may not vote on this poll
Hardtop hoist Poll
Old Apr 25, 2010 | 02:40 PM
i--_--i's Avatar
Default Hardtop hoist Poll
Harken Hoister
Top Cap EZ Lift
Hoist-a-Top
Old Apr 25, 2010 | 02:42 PM
Jeff's Avatar
Vet Army
Harken Hoister
Old Apr 25, 2010 | 03:19 PM
WavetheWheat's Avatar
I bought a Racor Heavy lift from Costco for right at $100. (also available on Amazon) http://racorinc.com/Products.aspx?id=150
Two 69" 2x4's
Two 69" 2x6's
8 eye bolts/nuts/washers
8 barrel bolts
$10 in chain
The hoist is awesome. Tons of room on top (or the shelf that goes up and down) for freedom tops and other items. It goes up and down with my cordless drill. I put the 2x4s on top with chains attached and the 2x6s under the top (I liked the bigger board to spread out weight) When you take the top off its easy to slip the boards under the top, back jeep into position, drop the chains down and drop the hoist, screw the barrel bolts closed, put freedom tops on shelf, use drill to raise hoist to ceiling, and drive jeep off.. It takes me about 10 minutes to get top off and top is stored out of way. The whole thing should be less than $150.
Here is the finished product. Super easy (I am not very handy)
Old Apr 25, 2010 | 07:46 PM
pastorsteve's Avatar
Default None of the above
I made my own too for about $35. For me, there's no need to buy something that does the same job that costs a lot more. Four pulleys, four Eye-bolts, two tie-down rings, four carabiners. Pretty simple. Tight up against the ceiling so it's easy to walk under and not in the way.
Old Apr 25, 2010 | 07:56 PM
seabass's Avatar
Made my own.
Old Apr 26, 2010 | 07:28 AM
PeterWendy's Avatar
I just use the ratchet type tie downs.
i only need to ratchet it up 1" then drive out.
When I want to lower it I just rachet it back down. It is only 1" so it does not take long.
Old Apr 26, 2010 | 09:13 AM
z4string's Avatar
I made my own based on the Hoist-a-Top design, but much stronger and cheaper. You can get uni-strut, hardware, cable, pullies etc. at home depot. I bought a nice brake winch from Northern tool for $60. Total investment < $150. Incredibly easy to use and I hoist my soft top up for winter storage. Made for a fun and satisfying project.
TW
Old Sep 4, 2010 | 08:05 AM
4play's Avatar
Racor for me
Old Sep 4, 2010 | 09:18 AM
wallawallaron's Avatar
Two 69" 2x4's
Two 69" 2x6's
8 barrel bolts
$10 in chain
Like your set up. Can u tell me or do u have a pic of what barrel bolts are ? Thanks
Old Sep 4, 2010 | 09:26 AM
tommyluv78's Avatar
TW
i did something similar. got my material from work cost me next to nothing.
