Hawks EBC Green Stuff brake pads - opinions
Old Apr 26, 2011 | 03:23 PM
Tuto's Avatar
Default Hawks EBC Green Stuff brake pads - opinions
We are getting ready to change the brake pads in our jeep and was looking at the Hawks EBC Green Stuff brake pads. We wanted to know if any forum member has used them.
Green powder coated against rust
Features
•Fortify your speed demon or heavy rig's brake pedal with EBC Green Stuff Brake Pads
•EBC custom builds your Green Stuff Brake Pads to directly replace your stock pads
•Formulated for spirited street driving—your EBC Green Stuff Brake Pads immediately clamp down hard as soon as they touch your rotors
•The beveled edges, factory-fitted shims, and center-line slot on each EBC Green Stuff Brake Pad fight off squeals for ultra-quiet stops
•30% less dust than OEM replacement pads, on average
•EBC's unique Break-In surface coating delivers rapid bedding for maximum braking power fresh from the box
•All EBC Green Stuff Brake Pads feature a center-line slot that vents in cool air to prevent thermal cracks
•The pads and the pad plates are green powder coated for a lifetime of rust-free service
•Choose the right EBC Pads & Rotors: Brake Pad & Rotor Selector Chart (Adobe Acrobat required)
•EBC backs your Green Stuff Brake Pads with a 12 month/10,000 mile warranty
Description
When you’re tearin’ up the streets in your high-powered auto, you need speedy brakes to avoid costly accidents. Arm your calipers with EBC Green Stuff Brake Pads for hair-trigger pedal response. These pads don’t wait around to sink their teeth into your rotors—they bite hard and hold fast for sure stops.
As soon as your foot touches the pedal, your EBC Green Stuff Brake Pads get to work. They’re specially designed to deliver serious grip from the moment they hit your rotors. Plus, they stay strong until you come to a halt or hit the gas.
Your EBC Green Stuff Brake Pads are as quiet as a mouse. Their beveled edges, shims and center-line slot muffle screeches, squeaks and whine. Not just quieter, these performance pads also make very little dust—about 30% less than stock pads.
Bedding is near instantaneous with your EBC Green Stuff Brake Pads. A unique Break-In surface coating makes your pads work strong right out the box. Covered by a 12 month/10,000 mile warranty
Notes
•It's always best to use the same compound in the front and rear, but if budget restraints prevent that, use this guide:•When using Green Stuff Brake Pads on the front and replacing the rear, it is recommended to use either a set of Green Stuff, Ultimax, Red Stuff or original brake pads for the rear.
•When using Green Stuff Brake Pads on the rear and replacing the front, it is recommended to use either a set of Green Stuff or Yellow Stuff Brake Pads for the front.
Old Apr 26, 2011 | 05:07 PM
remlle's Avatar
I used the EBCs on my Camaro and they did stop better and quiet as could be. the issue I had was they really made a lot of brake dust. all be it the dust washed away without soap but its annoying. If you dont care about the dust then go for them they are awesome.
Old Apr 26, 2011 | 06:01 PM
sm_rubi's Avatar
We are using them they are quiet but I heard the complaint about them is they are hard on rotors and I know we have a groove in one now that wasn't there before. Could be coincidence who knows but we went with Hawk on the rears.
Old Apr 2, 2012 | 09:44 PM
inhlengr's Avatar
Gave them a try at my last changout of the fronts. As far as function they worked great on my winding mountain roads. No more or less dusty than the Hawks or the Napa pads that I used before. However these wore out faster than all the others. Was surprised how quickly they wore down under same driving conditions as before, luckily caught it during my last rotation of the tires.
Old Apr 2, 2012 | 10:14 PM
ER NURSE 407's Avatar
+ 1 , they breakdown way faster than OEM or Autozone pads.
Old Apr 3, 2012 | 03:41 AM
Mike Davis's Avatar
I'm using Hawks and really notice the improved braking over stock. Only have done rears. Rears wear out much faster than fronts.
Old Apr 3, 2012 | 09:05 AM
Space Monkey's Avatar
I use Hawk products on everything from a 240SX, 350Z, to my Jeep TJ. Never have they failed me in any situation.
Old Apr 3, 2012 | 10:25 AM
8000ft's Avatar
I'm fairly sure that Hawk and EBC are 2 different companies. I'm looking into the Hawk LTS pads because I've heard that they are a bit "nicer" to the rotors.
Old Apr 3, 2012 | 11:09 AM
yo_marc's Avatar
Ran EBC Greens in a Dodge Magnum. Other posters have stated the same experiences... hard on rotors, and lots of brake dust. The brake dust (or debris in my case) actually ate into the coating on the front wheels; The brakes seemed to shed small specs or pellets of debris that adhered to the wheels coating.
On the plus side - they had excellent bite and feel. Very confident brakes.
FWIW, running EBC Reds on a motocross bike and LOVE them in that application. :P
Old Apr 3, 2012 | 01:13 PM
juanburgundy's Avatar
I just installed the LTS pads on my rear brakes and they are great! Easy install, no noise and very smooth / responsive brake feel. Highly recommend!
