Headlamps out!!!
Subscribe
Mar 21, 2011 | 07:07 AM
Hey All,
This morning heading into work, I noticed that my headlamps do not work? I can flash on my brights and they stay on for a second and then I get nothing.
Could this be a fuse issue? Any thoughts or ideas would be great!
Side note: All my other lights work - fog lights, break lights, turn signals...
Thanks!!
Parker
Reply 0
Mar 21, 2011 | 07:11 AM
Are they the stock lights or have you upgraded to the the IPFs or something along those lines?
Reply 0
Mar 21, 2011 | 07:13 AM
Check for water in the housing. It could have fried your bulbs if it's not properly sealed.
Reply 0
Mar 21, 2011 | 07:18 AM
Headlamps
They have been replaced. Its just weird that both would go at the same time...
Reply 0
Mar 21, 2011 | 08:09 AM
It might be weird but it could happen. They could have done it overnight.
Did you replace them yourself? Or did you have a shop do it for you?
Reply 0
Mar 21, 2011 | 08:24 AM
Headlamps
I did them myself. I'll check them when I get home this evening. Do you know the fuse layout so I can check that as well?
Thanks!
Parker
Reply 0
Mar 21, 2011 | 06:43 PM
headlights will go at the same time a lot, I have had it happen prob 3 or 4 times.
Reply 0
Mar 21, 2011 | 07:25 PM
Could be a bad relay; worth checking while you're inspecting the fuses.
Reply 0
Mar 21, 2011 | 07:38 PM
Try pulling your negative cable for thirty minutes. Sometimes it clears bugs. Like a reboot
Sent from my PC36100 using Tapatalk
Reply 0
Mar 22, 2011 | 08:10 AM
When I upgraded to IPF's, mine went out due to a poor connection at the harness. I ended up cutting off the connector altogether and just hardwiring them together. Works like a charm now!
Reply 0
