Heater Core replacement
Old Jan 8, 2019 | 10:41 AM
Kosta0601's Avatar
Default Heater Core replacement
Could anyone out there please let me know what the correct replacement heater core is for a 2009 Jeep Wrangler Unlimited Sahara 4 door, six cylinder 4x4? A link would be great if possible. Thanks!
Old Jan 8, 2019 | 11:38 AM
ronjenx's Avatar
Search the internet for this part number: 68004193AB
Old Jan 9, 2019 | 06:18 AM
Kosta0601's Avatar
Thank you!!!!
Wish the job to replace wasbas easy as it is to get a response. Looks to be a very involved process!
Old Jan 9, 2019 | 06:21 AM
ronjenx's Avatar
Originally Posted by Kosta0601
Thank you!!!!
This is a thread showing how to replace the heater core without having to take the dash apart. Heater Core Swap in 30 Mins
Old Jan 9, 2019 | 06:32 AM
07WrangX's Avatar
It isn't hard if you want to do it the easy way. Just cut the incoming and outgoing lines to the core, remove the bracket under the dash by cutting it, cut new lines to the same length, secure the core with heater hose and clamps, then pop rivet the removed bracket back into place using some small c channel. I fixed mine this way and have not had a problem. When it goes again, it will be another easy fix.
Old Jan 9, 2019 | 06:33 AM
07WrangX's Avatar
https://www.jk-forum.com/forums/stoc...0-mins-336039/
Old Jan 9, 2019 | 06:39 AM
Kosta0601's Avatar
Awesome......Thanks!!!
Old Jan 9, 2019 | 08:27 PM
tjkamp's Avatar
Did mine this way in 2.5 hours last Saturday, including bumping the system afterwards (would have been quicker if I could have found my stupid hack-saw, haha!). Mines a 2013. I cut the bracket a little differently than some of the others, and was able to just leave it out. I lost one mounting screw below the glove box near the center consul, but you can't tell it isn't there, everything is still very solid. So I'm happy.
Old Feb 5, 2019 | 02:27 PM
BlkSlvrJK's Avatar
Are you guys using 5/8" heater hose for connecting?
Going to be doing this hack very soon
Old Feb 5, 2019 | 04:46 PM
Rednroll's Avatar
Yes, 5/8" heater hose is what I used.
