Sponsored by:
Sponsored by: DashLynx
Help identifying this
Old 12-11-2017, 03:01 PM
ttwntec's Avatar
Default Help identifying this
2008 JKU stock.
Driving the other day and it started smoking out the passenger side. Prior to getting home the check engine light camel on. It started leaking coolant from underneath. That is the only fluid I'm low on and taste. When I looked there was fluid on top of this and around it.
Location
Passenger side underneath the transmission dip stick. It has a connector on top and on the side towards the bottom a metal line.
The only codes it low O2 voltage, normal with the engine off, and no permanent codes.
Any help would be appreciated.
ID:	676380Click image for larger version
ID:	676381Click image for larger version
Old 12-11-2017, 03:17 PM
ronjenx's Avatar
EGR valve.
Quick Reply: Help identifying this
