Help removing airbag
With that Synergy TR, to adjust toe all you really have to do is loosen the pinch bolt and then rotated the double-barrel adjustment sleeve. That said, most alignment guys don't know to do that so they do it the old fashion way by loosening the jam nut and removing one of the TREs from the knuckle and rotating it, then reinstalling. The fact that the stabilizer clamp was not moved is not an indication of no alignment done. That said, the only thing they really would have done with an alignment is adjust toe and straighten your steering wheel.
The idea that the dealer you took it to never did the original recall work is something to ponder. I think the liability of not actually performing that recall work and saying you did would be way too great for any dealer. It could be likely that they did replace the airbag and the new shroud they had just wasn't the updated one? Can you imagine the legal liability if that jeep had been in a fatality crash where that airbag was faulty and it could be proven it had not been replaced? It seems that could be detrimental to a dealer and not something they would risk.
As you can tell, this dealer really grinds my gears.
Bump to the top as of like to get and get this repair done. My plan is back to work Monday and I'll bend a harbor freight screw driver and see if I can get a longer 90 degree hook.
Any advice on this one since my steering column doesn't seem to have the normal cutouts? I'm assuming the tiny cutouts at around 10:00 and 2:00?
can you give me any pointers on how to remove the air bag. I do not have the access points.
