Help--Roadside Emergency
Old Mar 23, 2011 | 06:02 PM
jfreeddo's Avatar
are you an auto? can't remember.
If so, make sure you are firmly in park before starting.
Maybe even try putting in Neutral and try starting.
Old Mar 23, 2011 | 06:03 PM
u-joint's Avatar
Originally Posted by u-joint
Yes...
Here is her thread...
https://www.jk-forum.com/forums/show...ad+clockspring
Since you are on your phone I will read up a bit, and let you know if there is an "easy" solution.
Oh.... I read somewhere where someone had to "punch" their steering wheel when something like this happened.
No... Mark, your issue does not sound like Toad's issue.... I saw no mention of lack of electricity.
Old Mar 23, 2011 | 06:04 PM
u-joint's Avatar
He has a standard.... I thought about suggesting him to push start it.... but I can't imagine they'd do any good if it's an electrical problem
Old Mar 23, 2011 | 06:11 PM
u-joint's Avatar
And herehe is
Let us know how it goes.
Free bump, so more people can throw some ideas out there
Old Mar 23, 2011 | 06:30 PM
shockwaveaz's Avatar
Try reseting the sentry system. Look for the big whit fuse holder with two 60 amp fuses in it. Pull up the white part for about 45 seconds.
Sent from my PC36100 using Tapatalk
PainKiller's Avatar
ground problem or if there has been any electrical work doen lately I would check to see if one of the wires has rubbed or is rubbing on metal causing a short in the system
Old Mar 23, 2011 | 06:37 PM
I think it's J13 fuse
Old Mar 23, 2011 | 06:39 PM
Mark Doiron's Avatar
Tried to jump start. It starts then as soon as I press clutch engine dies--even after running for five secs or so. Tried three times. Now towed to friends home.
Old Mar 23, 2011 | 06:40 PM
What does that fuse?
Old Mar 23, 2011 | 06:46 PM
Sentry security system. Do you have remote start?
