Help with soft top?
Thanks in advance for the help. I am about to purchase a soft top for a 2-door JK from another Jeep owner. I currently only have the hardtop. Can somebody tell me which brackets should be included for proper installation?
Thanks
Thanks
Have a look in your manual for the fine details, but you will need to be sure that you get the two brackets and 4 screws that attach to the 'sport' bar; all the frame that is attached to the top; 4 screws that attach the frame to the aforementioned brackets; the bar that holds the bottom of the rear window, and the two plastic brackets that hold the rear window bar in place.
Also the plastic door trims, and knobs that go with them.
That should be it.
SV
That should be it.
SV
