Help Steering Shimmy
I have a mech question for you. Bad shimmy side to side at only 55-60mph. But can feel it in fourth through sixth gear. No metal clanking that I can hear.
Have you had the tires balanced recently or rotated?
That shimmy is usually an out of balance tire. Since they were just balanced and rotated, I'd give them another rotation and see what happens. If you feel it move then you know it's balance. If it goes away entirely then they may have zipped your lug nuts on without proper torque applied.
The rotor retainers have been removed from the front, correct?
Side to side shimmy - I would also check your track bar bracket to make sure it isn't wallowed out (aka the beginning of death wobble). Check all of your suspension torques just to be safe. Also, I don't know the entirety of your situation but check tie rod ends, drag link ends, etc.
