Help tranny
Old Aug 18, 2013 | 02:45 PM
mook8651's Avatar
Default Help tranny
Just changed my fluid an the tranny didnt even take a full 2qts before it started to come out the fill hole. I'm about 4-6oz shy of a full 2qts can this be a problem
Old Aug 18, 2013 | 06:58 PM
Mike Davis's Avatar
In the 2 auto trans fluid changes I've been involved, both 2008, 3.8. We drained as much as possible (suction out via the trans dip stick tube) dropped the pan and replaced the filter. It took 7 or 8 quarts. How much did you drain? It should take at least that much. Check JK write ups on the forum.
Old Aug 18, 2013 | 07:40 PM
mook8651's Avatar
Well I have a manual so I have a fill an drain plug. It only take a tad over 2qts from what the write up says an the manual says it take 2.135 qts but mine didnt even take a full 2qts
Old Aug 19, 2013 | 02:07 AM
airforce26yrs's Avatar
Your not parked on an incline are you?
Old Aug 19, 2013 | 04:39 AM
mook8651's Avatar
Nope level ground in my garage
Old Aug 19, 2013 | 05:17 AM
ChesterJFK's Avatar
You sure you pulled the tranny plug and not the transfer case?
Old Aug 19, 2013 | 05:25 AM
mook8651's Avatar
Lol yeah I changed both tranny fluid an transfer case. I drove it to work last night which is a 52mile round trip not a problem. I just thought it was weird that it didnt even take a full 2qts
Old Aug 19, 2013 | 05:26 AM
mook8651's Avatar
I just wanted to know if anyone who changed there fluid experience this
