Help with waterpump..
Old 04-23-2013, 11:02 AM
  #21
TYDFAN's Avatar
Originally Posted by yo_marc
Hardest part for me was separating the pulley from the original water pump. Didn't have a puller big enough, and didn't have luck with any prying. Ended up coaxing it off with a BFH.
Puller? BFH? My pulley on my 07 easily unbolted.
Old 04-23-2013, 11:27 AM
  #22
yo_marc's Avatar
I wish I was that lucky! Mine was pretty well bonded on.
75% of the time I put into the job was probably spent getting the pulley free without destroying it, and putting a spring loaded hose clamp back in place. It really shouldn't have been that hard...
Not sure if it mattered either, but I did the job at about 110K miles.
Old 04-25-2013, 01:30 AM
  #23
Dr.McNinja's Avatar
https://www.jk-forum.com/forums/jk-w...cement-124942/
It's not terribly hard.
Old 04-25-2013, 02:05 AM
  #24
corsair61's Avatar
My water pump was leaking, no waterpump available in New Zealand (unbelievable) all ex USA, so went and bought some gaskit paper and some good quility silicon sealer cut out new gaskit, coating of sealer, problem fixed for a few bucks.
Old 04-25-2013, 04:34 AM
  #25
jdk
jdk's Avatar
I had a leakey waterpump as well, on my 07 JKUR, 07-09 had these issues. Replaced mine for $40. took me about hour and a half, replaced the belt also.
Old 04-25-2013, 06:27 AM
  #26
305jk's Avatar
Guys thanks for all the help.. I was finally able to tackle down the pump last night.. no more leak.. Was such an easy job.. The only problem I had was the dain plug in the radiator not drainning any coolant.. So I just made the mess and took the pump out with all the coolant in the engine still... Now im jeep beach ready
Old 04-25-2013, 09:13 AM
  #27
yo_marc's Avatar
I heard that the radiator drain plugs are unreliable... When I did my pump, I ended up pulling the lower hose off the engine block to drain the coolant.
Old 10-27-2015, 06:27 AM
  #28
Mike Dutson's Avatar
Default thought same thing but was told this...
Originally Posted by JKMoses
Hi 305jk
If your car is 2008 or +, and if you are the first owner then you have lifetime powertrain warranty in some components of your engine, the waterpump is covered by that warranty.
I just changed mine after 162k miles and my warranty covered the price of the waterpump. My JK is 2008
Go to dealer and ask them.
I have a 08' JKU, waterpump has slow leak, called the 1-800-992-1997 number and they told me that my warranty was void because I didnt bring my Jeep in for the 5 yr inspection!!
Old 10-29-2015, 10:33 AM
  #29
jumpinjoe's Avatar
Default sux
That sucks but they are right - every 5 years you must bring your 2008 Jeep in for an inspection at a dealer.
Old 10-29-2015, 04:27 PM
  #30
fultonromero12's Avatar
Glad you were able to get it fixed without too much issue. I just did mine this past summer. Stupid me used just the gasket and no rtv....needless to say as soon as I was done and cranked it the antifreeze started weeping from the gasket.. Used the orange rtv the second time and it's been going strong without a drip..
Quick Reply: Help with waterpump..
